VW California
Caravan
Drive-Away Awnings
Tents
Sunncamp Swift Caravan Canopy 390
£164.00 Inc VAT
In stock
Found this item cheaper?
SKU: 5039150226805 Categories: , Tags: , ,
The Sunncamp Swift caravan canopy 390 is a large canopy perfect for protecting you from the elements – stylish and easy to set up.
  • Two side picture windows
  • Steel and fibreglass frame
  • 1 x aluminium roof pole included
Specifications
  • Height Range 235 – 250cm
  • Floor plan size 390cm width x 240cm depth
  • Approx. pack size 79 x 18cm
  • Approx. weight 7KG
Please be aware this product is designed to be raised slightly off of the ground. – If you require something that seals to the floor take a look at the Sunncamp 390 porch awning.
SF8000
Weight 8 kg
Dimensions 83 × 22 × 22 cm
Sunncamp
SunnCamp has been manufacturing outdoor products including Caravan Awnings, Motor Awnings, Trailer Tents and Tents for over 38 years.
Be the first to review “Sunncamp Swift Caravan Canopy 390”
You may also like…
£164.00 Inc VAT
