VW California
Caravan
Drive-Away Awnings
Tents
Vango Cove III Low Air Drive Away Awning – New and Updated for 2024
£624.99 Inc VAT
Out of stock
Email Me When Back in Stock
Vango Cove III Low Drive Away Awning – Roof Rail Connection Height: 180cm to 210cm
Coming in new for 2024, the Vango Cove III is an updated model of the previous well-known Vango Cove II. The main difference is that the 2024 version is now made out of the Sentinel Active 150D Fabric rather than the standard, meaning the fabric is a thicker and stronger fabric.
The Vango Cove III is the ideal size for ample storage room, socializing or creating an additional sleeping section. The pre-attached front canopy creates a great outdoor seating area to enjoy the views regardless of which side of the van you attach to. Utilizing Vango’s Airbeam technology and Sentinel Active 150D Fabric, it is quick and easy to pitch whilst being light, waterproof, and durable.
The Vango Cove III is supplied with steel tent pegs, pre-attached guylines, and an Airbeam Pump.
  • Sentinel Active 150D Fabric
  • Inflatable Airbeam Structure
  • Pre-Attached Front Canopy
  • Diamond Clear Windows
  • Side Attachment
  • Mesh Front Door
  • Two Doors in Tunnel Attachment to Vehicle
  • Covered Entry
  • Toggled Privacy Curtain
  • Easy Pack Carry Bag
  • Airzone Ventilation
  • Tunnel Adjustment Strap
  • Lantern Hanging Points
  • Multiple Vehicle Attachment Methods
  • Pre-Angled Beams
  • Roll Away Connecting Tunnel
  • Fully Sewn-in Groundsheet
  • Clear Visibility Guylines
  • TBS II Tension System
Specifications
  • Weight: 17.3kg
  • Packsize: L 74cm x H 41cm x W 41cm
  • Pitching Time: 10 mins
  • Awning Size: Low
  • Kador Adjustable Height: 180-210cm
  • Height: 205cm
  • Length: 310cm
  • Depth: 320cm
AWUCOVEAI000002
Weight 14.5 kg
Dimensions 80 × 45 × 42 cm
Vango
Be the first to review “Vango Cove III Low Air Drive Away Awning – New and Updated for 2024”
You may also like…
  • Vango Drive Away Awning Kit 6mm to 6mm (3m Length)
  • Vango Footprint Tent Awning Ground Protection Sheet 3m x 2.45m
  • Vango Airbeam Turbo Pump – Phantom
£624.99 Inc VAT
