Micro Steel Chair
Vango Strong Micro Steel Chair – Mykonos Blue
£24.99 Inc VAT
Only 1 left in stock
The Vango Micro Steel Chair is a compact, sturdy and durable chair which is the perfect match for festival goers, first-time campers and trekkers due to the incredible pack size and weight of only 1.5kg. Simply pack away into its own handled carry bag for easy transportation.
Fitting into its own little storage bag, the Vango Micro Chair is great if you are tight for space. Whether you’re cycling, campervanning or haven’t got much room left in the car, the Vango Micro is the ideal chair for sitting round the campsite at the end of the day. As it packs away into such a small space it would be perfect if you are limited in space in your caravan or motorhome.
  • Steel frame – Strong and reliable
  • Endure fabric – Very strong and durable polyester fabric designed for outdoor use
  • Foldable to compact size – Easy storage and transport
  • Maximum loading weight: 120kg/18st 12lbs
  • Handled carry bag – Provides easy transportation to and from the campsite
Specifications
  • Weight: 1.5kg
  • Packsize: L35.0 x H9.0 x W11.5cm
  • Max Load: 120kg
  • Chair Depth: 53.0cm
  • Chair Width: 55.0cm
  • Chair Height: 64.0cm
  • Seat Height: 34.0cm
  • Seat Width: 54.0cm
If you would like a larger upgraded version of this chair check out the new recline model —>Here
Vango
Be the first to review “Vango Strong Micro Steel Chair – Mykonos Blue”
You may also like…
  • Vango Adjustable Steel King Poles ( 180-220cm)
  • Vango Sunbeam Flexi 2m Awning Lighting USB
£24.99 Inc VAT
