Campervanbits VW California 2 section bunk ladder
Gives you easy access to the upper bed without the need to climb on the front cab seats, the ladder coming in two compact sections is very easy to store in your California with its storage bag that it comes with. The storage bag comes with straps that allow you to hang on the rear seat headrest.
- 5 rungs
- Aluminum construction
- Easily attached to the rear bench seat when not in use
- Can also be used outside the vehicle to reach roof bars, roof box etc…
- Rests against the roof opening of the California (or other campervans).
- 100kg maximum weight limit
Specifications
- Width: 30 cm
- Length when folded: 78 cm and full length: 150 cm
- Weight only 2.3 kg
- Included in package: 2 section ladder & Storage bag
First item reviewed in the video below is the ladder
Please be aware we no longer include the fitting kit as this is not required with most campervans.
People tend to not want to screw this into their van, If you require the fitting kit shipping with the ladder please let us know and we’ll include it in the parcel.
| Weight | 3.500 kg |
| Dimensions | 40 × 13 × 98 cm |
