GollyOlly
Over inflate on the tyre pressure by a pound or two using the Ring and then use your tyre pressure gauge to zero in the pressure. Don't trust the Ring indicator as it is not accurate.I have an older version of the Ring inflator which is good but like the newer one it has a screw on connector which annoyingly lets the air pressure escape as you're unscrewing it-so i bought this adaptor & extension which works very well.
Ancable Air Tyre Tire Chuck, 15CM Motorcycle Valve Air Rubber Hose Locking Tire Chuck Tire Inflator Pump Hose Adapter + 2 Pcs Brass Tyre Valve Air Pump Clip Thread Nozzle Adapter Truck Inflator Valve : Amazon.co.uk: Automotive
Buy Ancable Air Tyre Tire Chuck, 15CM Motorcycle Valve Air Rubber Hose Locking Tire Chuck Tire Inflator Pump Hose Adapter + 2 Pcs Brass Tyre Valve Air Pump Clip Thread Nozzle Adapter Truck Inflator Valve at Amazon UK. Free delivery on eligible orders.www.amazon.co.uk
