Only the 180 biturbo engine was affected, and not all engines. In fact a relatively small percentage.Sorry I know there’s been a million of these, but would a 2013 5.1 be free of the EGR issues which caused such problems on the 10/11 engines.
Would the EGR issue put you off buying a 5.1?
Some have electively changed the EGR valve to the latest version if oil usage is OK. Possibly worksThank you! Would it require a complete engine rebuild or is there preventative action that could be taken?
In the engine compartment, look downwards, at the front, to the L of centre. You should see the Oil Filter canister. To the left and below is the EGR valve and Cooler. There should be a label, white in colour, with the Serial number alongside the Canister.Thanks Alan.
As it’s not my Ocean, is theERG number easy to find in the engine?
Yes, except the label may be covered in oily grime. A quick wipe with a tissue and you will see the relevant number.Thanks Alan.
If it is truly an Ocean, (ie 2016 onwards) then you don't need to worry. The issue impacted the 180 hp SEs that started build in 2010. When it finished is very much up for debate, but I'd take any opinion stating it was all sorted by 2011 with a very large shovel full of salt.As it’s not my Ocean
That is plain wrong and needs to be corrected. I know a caveat is added later, but could clearly give the wrong impression.The high oil consumption issue relates only to the 180ps BiTurbo engine built during 2010/11
I was referring to the fact that only the 180 engine is affected, not the 140.That is plain wrong and needs to be corrected. I know a caveat is added later, but could clearly give the wrong impression.
The issue certainly seemed worse during these years (there has been talk of a block change after that point) but there are plenty of example well after that date range.
What % those examples are of the total made, and what is full range of causes will remain forever up for debate, but to say anything post 2011 is in the clear is simply not correct.
There have been 3 changes to the design of the EGR cooler, only the last (/d) is thought (hoped) to have solved the problem.
There was a very specific manufacturing issue with the EGR designed and installed on early 180ps engines between 2010 and 2011. VW knew about it to the point of knowing the engine numbers affected. This issue lead to the updated coated Alloy EGR cooler as a result.That is plain wrong and needs to be corrected. I know a caveat is added later, but could clearly give the wrong impression.
Twas only mentioned yesterdayHi, There does not seem to have been any recent chat on the issue of excessive oil consumption for the 180PS 2010/2011 California....
I had this problem with a 2012 180bhp bi turbo at 60,000 miles and it was a real headache. Even VW had problems sorting it. Having spent several thousand I got rid of it!The high oil consumption issue relates only to the 180ps BiTurbo engine built during 2010/11. I was told, when my Cali became affected, that VW knows the serial numbers of faulty engines. Some 180ps engines in later years were also affected but to a much lesser degree.
The reason for this was that the EGR was a made of alloy on the 180 (other engines have a different design) and as exhaust gasses are recirculated through it, cooled and then passed back into the inlet of the engine, the alloy was corroded inside the cooler and an aluminum oxide passed into the inlet wearing the piston bores, hence the higher oil consumption.
The way to check is to have a look at the serial number on the EGR. This is located on a plate on the alloy housing to the right of the base of the oil filter. This is at the front bottom of the engine behind the radiator and can be seen easily from above. If the part number has a suffix number (A, B, or D) then the ERG should be fine. If there is no suffix, then personally I would have a look for another van.
There is a Facebook page where this issue is discussed at length.
Having said all that, other engine powers are not affected with this issue and as WG has said, not all 2010/11 have succumbed.
Good luck,
Alan
Good luck,
Alan
Hi Alan ,
Is this bad ?
Have you considered having an oil analysis done to see if there is aluminum oxide contamination? At best it could set your mind at ease, and at worst you could detect a problem before damage is done.Our 14 reg has a A suffix EGR and has about 68k on now and no problems as yet. Oil change at least once a year and only use premium brand fuels which personally I think probably helps.
I must admit I would be a bit wary of buying a secondhand one unless it had a good provable service history as above.
