Accessory key position 1 - timing out
PaulGC680
PaulGC680
United kingdom
Grand California 680
Hi
When parked up and relaxing in our GC680……
With the ignition key engaged and rotated to position 1 - the accessory position
The radio and multimedia are active. And in that position the ignition is off.
The problem is that it times out after approx 15 minutes.
To continue listening the key has to be turned off and turned back to position 1.
Tricky with the drivers seat rotated, or when sat outside.
Do any of you know if this ‘time out’ period can be extended?
If so how is it done
Many thanks
You don’t need the key in to listen to the radio, just turn it on. It still times out, on mine it’s about 20-25 mins.
  • Agree
Reactions: Sad
Meoncoast
Meoncoast
Meoncoast
Amarillo
8K
Hotel California
H
