ADVANCED AGM LP100 LEISURE BATTERY 100AH 12V
altvic
altvic
N Wales
T6 Ocean 204 4Motion
I am just about to purchase two new 100 ah leisure batteries. They are to replace the original 85 ah batteries supplied with the 2017 cali. Just occurred to me that as I will be upgrading by 15ah (85 to 100ah) I might need to upgrade fuses ie the one on the battery terminal, is this correct?
Many thanks
Many thanks
I'm not an electrician but if you upgrade the Cube Fuse to a higher capacity then that would mean a higher current flow before it failed. Could the wiring between the 2 batteries take this increased load?
Many thanks
There will be a small drop in (new rated) battery internal resistance. This will potentially increase the max charge and discharge current very slightly.
I would leave your fuses alone and keep an eye on the cube fuse. If it pops consider upgrading the rating slightly.
Many thanks
Sound like a decent upgrade. I wonder if my Beach 75ah leisure battery could be replaced with a 100ah when the time comes.
Anyone with a Beach done this?
Thank you, both @WelshGas and @yossarian The battery shop advised this battery as exact size as the VW originals but only 256£ for two and free delivery tomorrow. I'll let folks know if anything untoward happens. Thanks again.
Where did you buy the battery’s from ?
Advanced Battery Supplies:
Roger Boeken
Roger Boeken
paolino
paolino
paolino
D
Emil Silenhag
Emil Silenhag
Sp0_0k
Sp0_0k
Sp0_0k
