G
gregspam
- Messages
- 58
I recently purchased a new headunit to replace my RCD310. Quite impressed with the quality of it so thought I'd post a review on youtube to help others out.
Cheers,
Greg
Cheers,
Greg
1) Sound quality - how good? Spec states "50w x 4" amps - RMS or PMPO? (the former would be good!)
2) Does it have 4 x pre-outs for connection to remote amps?
3) The canbus support - needs no dealer intervention to code it in? The reversing / climate options just work?
4) How about Bluetooth with existing VW BT prep ? Could it use the external mic?
5) Controls - I don't have MF steering wheel but all the DIS options present via canbus and the right stalk buttons can access the unit?
I've got the standard California speakers which aren't great so it's hard to tell just how good the quality is. The guys over at XDA who have better setups seem to suggest it's good though. The radio reception is fine too, though it might be improved by having a proper dual fakra adapter (I have it plugged into just one).
Believe output is closer to RMS, but take a look here. Lots of details that enterprising souls have measured all sorts of outputs.
I believe it has 2x pre-outs, again details at the above link.
Just works out of the box for reversing sensors and climatronic, no dealer intervention required.
I didn't have the VW BT Prep so hard to comment, but the mic is just a 3.5mm jack, so if the VW BT prep mic has one of those I don't see why it wouldn't be a simple swap.
Not sure re the stalk you mention. Worth noting that the only thing this unit doesn't do is present radio/track information or Nav instructions in the DIS. It just displays Volkswagen Audio, Volkswagen Navigation or something similar. I think Nav in DIS is only ever going to be available on OEM units as its so tied to the (relatively poor) VW Nav software implementation. Shame but not a big issue.
Regarding TomTom, in theory yes easily possible, but I understand there is a widely known problem with TomTom not working on a lot of Android tablets due to a problem with the way TomTom reads the GPS signal.
4 x 28W RMS which is a little weak
I'm no expert on this, but I believe all OEM headunits are 4 X 20W, so this unit is potentially an improvement on stock.
Like you said the factory speakers are quite poor. I've thought about upgrading the speakers but been put off by stories of speaker grilles being plastic welded. Thought of removing door cards etc is not something I'm keen on with a nice new vehicle. What's your experience?
My experience, and I spent some while considering options, was to leave the front speakers alone & avoid almost certain damage to door cards / poppers and put the effort into the rear which is a lot more useful when parked up anyway. I installed Focal component speakers into the rear drop down cupboards, a 4 x 100w RMS amp and a modest but decent quality 8" Rockford sub which tucks in under the gap to the n/s side of the sliding seat. I connect via Bluetooth with an Arcam min bLink ( http://www.arcam.co.uk/mini.htm ) which is hard-wired to the 4 Kenwood 4 x 100w amp. It was a bit of a job but resultant sound worth the effort.
The OEM RNS 310 GPS does ok for driving and the GPS is adequate - it also has full Bluetooth prep which works well.
Hope that makes sense? Can offer advice on upgrading the rear speakers as required.
Sounds good.
How does this work exactly, do you switch to Bluetooth from the the headset?
Not sure what the extra Arcam unit is for, guessing you don't physically have the amp connected to the head unit?
I typically use my smartphone as the source and allow it to Bluetooth connect to both the rear amp (via the Arcam bLink which has a far superior DAC to any smartphone) and also connect it to the OEM RNS 310 for taking calls etc. So yes, you are correct there is no wired physical connection.
Thanks, so volume / music control all takes place on the phone?
Correct. Sits on the convenient tray in the top of the front dash.
I can use the OEM whilst driving as twiddling with a phone is definitely not a good plan ! (major cause of RTAs I suspect and just plain irresponsible)
