CannonDale
Does anyone know if the T6 (2016) has the newer type of aircon gas or the old type that is being phased out.
Thanks for this, I have black caps.Hi you would be in the change over period look under your bonnet at the air con pipes the connectors for regasing are at the back of the engine bay against the bulk head in a direct line from the coolant bottle. If you have black caps it’s the old gas if u have gray caps it’s the new gas
Vw guru, do you know if it is possible to change the system to the new gas. ThanksHi you would be in the change over period look under your bonnet at the air con pipes the connectors for regasing are at the back of the engine bay against the bulk head in a direct line from the coolant bottle. If you have black caps it’s the old gas if u have gray caps it’s the new gas
