N
Nigel Whitwood
Guest User
Hi,
I have Alcantara and one seam on the rear seat cushion, between two vinyl sections, has started to give way. The underlying base material seems ok but the vinyl layer itself has started to "delaminate" at the stitches. I can replace the cover at a significant cost but am loathed to do so if this is a common issue should the new one do the same after a few years. Has anyone had similar problems? (2018 Ocean).
