Cali Phillip
Been using one of these for the last three years, been very good. Other lower pressure versions were not durable and failed. https://www.amazon.co.uk/Ring-RAC830-Digital-Inflator-Function/dp/B016UGRYZQ
It’s great for in the van for a quick hoover, it’s not as good as a vacuum you use in the house. It’s a cube so really easy to store, and we use it to shrink our vacuum bags that we keep our bedding inI know this is a swerve from the thread topic but how do rate the Worx vac?
Thanks. I’d bargained on it being less powerful as it’s portable. It’s definitely for the van I’m thinking.It’s great for in the van for a quick hoover, it’s not as good as a vacuum you use in the house. It’s a cube so really easy to store, and we use it to shrink our vacuum bags that we keep our bedding in
Please explain, weight on the tire does not change pressure in tire. ..Even a 12v pump will need jacking up the van to remove weight off the tyre, otherwise it takes a really long time to get the needed pressure, and it will probably overheat by then and stop working.
Same as trying to inflate an inflatable mattress with someone on top.Please explain, weight on the tire does not change pressure in tire. ..
You stop at gas station and jack up the van to adjust pressure of tires ?
