W
Wiza
Having major issues attaching a drive away awning! The rail is 8mm no Hadith strips available that size nothing holds it securely! If it’s on the wind up awning it can pull out in windy weather! Help any suggestions?
You'll need to use the wind out as the rail is designed to take a rubber awning strip in order to make it suitable.Having major issues attaching a drive away awning! The rail is 8mm no Hadith strips available that size nothing holds it securely! If it’s on the wind up awning it can pull out in windy weather! Help any suggestions?
