sidepod
- Messages
- 6,973
- Vehicle
- T4 PopTop
Nice looking job there. I presume that when I get around to fitting an Awning, I wont be able to use the brackets you used due to the Brandrup rail fitted to my Cali. I think these brackets are my only option.Arrived and installed. I had to make up some 12mm spacers as per original Westy install.
It looks like the only option when a Brandrup rail is fitted. The gap is large enough, but I've seen some awnings with a rubber rain guard on the rear to prevent water from entering between the roof and awning. I'll research further.That looks neat. Nice small manageable gap to seal.
Ours is mounted on a rail. Never bothered fitting a rain guard. From memory I can only remember one occasion where the rain was coming through the gap. By that point I figured it was probably time to hide away inside the camper and crack open the gin. The rail itself works as a very effective gutter so captures a lot of the water and sends it off at either end.It looks like the only option when a Brandrup rail is fitted. The gap is large enough, but I've seen some awnings with a rubber rain guard on the rear to prevent water from entering between the roof and awning. I'll research further.
I know this is and old conversation, but I'm going to purchase an awning soon. I'm wondering if your awning is any or much higher than the top of the roof?Ours is mounted on a rail. Never bothered fitting a rain guard. From memory I can only remember one occasion where the rain was coming through the gap. By that point I figured it was probably time to hide away inside the camper and crack open the gin. The rail itself works as a very effective gutter so captures a lot of the water and sends it off at either end.
I have a Brandrup rail fitted so I have to use the same brackets as yours. I'm just keen to know if it will raise the overall height of the vehicle?
Regards Padraic.
Cheers for that. Is the awning the highest part?Just been to measure the height of our Westy. Floor to top of awning cassette is around 195cm. We’ve got a 40mm lowering kit on the suspension. The difference in height between the roof and the top of the awning cassette is about 5cm.
CheersI think it’s the F45 S 2.6m? I’ll measure in the morning.
