Chico
Hi, I have bought a 2007 T5 California
The leisure batteries seem flat.
I have had the van plugged in overnight but the batteries appear to be still flat or low as the roof is elevating fine??
The roof runs off the leisure batteries?? So there should be juice in the batteries, ? But not enough for the fridge to power??
The fridge doesn’t seem to work either
No on the front panel on cockpit headlining in front of van when you select fridge??
Should the fridge work plugged in to the mains Or will the fridge still not work if the batteries are too weak ??
How can I get the batteries checked before I buy new ones or one??
Garage electrical engineer??
Any suggestions on how to tackle this problem. Also if I do need new battery/s what make and power do I buy??
