David Green
Vader
My battery is being drained by0.2 amps constantly and e everything is off and nothing in any 12v plugs or the 150w any ideas appreciated
The console being on drains -0.2My battery is being drained by0.2 amps constantly and e everything is off and nothing in any 12v plugs or the 150w any ideas appreciated
If you are not using the Cali enough to top up the battery or are not on hookup. The power off is the bottom left button.So should I switch it off if that's possible?
The 0.2v is the draw for the screen . When the screen goes blank then that voltage drops to 0v. The screen will then be switched on by Ignition On or pressing any Control Panel button.So should I switch it off if that's possible?
Thanks for thisI was advised bij de the dealer to hook up a day or so if battery is getting low. Gets you back tot 100%. No problem, is normal.
Thanks for thisAlso immobiliser/alarm is obviously on all the time.
