John Caunce
Cauncey
Guys,
I've seen other posts on this but thought it was worth mentioning.
I'd noticed my fridge was cutting out when attached to a hook-up but plugged into the 12v sockets. It had been fine since new for nearly two years. Anyway I flagged up the issue when it went in for service.
After some tests the guys at the dealership found it to be faulty. After then having to remove the rear seats and rear panel behind the passenger seat it appears that the plug connector attached to the charger has worked loose because it wasn't connected properly. A 5mm movement saw it click into place and has resolved the issue.
Simples (when under warranty)!
JC
JC
