Bed stuck down!
Update; The backrest is now in upright position again. I managed to get a grip on the loose wire with a flat iron. Now I need to remove the back trim to to get the cable back in position. I afraid I might have to replace the release handle and even the wire, or both left and right wire. Any advice how to remove the trim? Spare parts? I haven’t found the backseat in any of the spare part webb sites.
Exactly what year is your vehicle?
from an earlier post - 2005.
Thought so, so parts are going to have to be searched for. Probably not easily available from usual sources.
The schematics are without the daybed backrest but I found it here.
Any use?
Select Campmobile and then Vehicle Year.
part codetitlenotequantitydata modelinformation
backrest for bench seat (day bed version)
padding for rear seat
head restaints
F >> 7H-6-040 800
rear2004.04 - 2009.05
-only order complete seat after agreeing in advance and providing vehicle identification number.
37H7 067 357 Abackrest frame1
4seat belt guide
see illustration, item:
857-70,12
57H7 067 409 Alocking sleeve2CALIFORNIA
COMFORTLINE
6adjusting element
no replacement part
for this use:
7H7 098 3942
-7H7 098 394 bowden cable
adjusting element
lowerX
7pin
no replacement part
not exchangeable
2
87H7 067 407 pressure springlower2
97H7 067 406 bowden cable
also use:
right lower
7H7 067 413
1;1
9A7H7 067 413 connecting piece2
107H7 067 082 gas filled strut1
117H7 067 547 bowden cableupper2
12N 90966701pop rivet6X138
13N 0123292retaining washer92
14pin
no replacement part
not exchangeable
121X51,5
167H7 067 367 Fpadding for backrest1CALIFORNIA
(16)7H7 067 367 Epadding for backrest1CALIFORNIA
COMFORTLINE
177H7 067 371 Eupholstery material (cloth)-BK1PR-N2J
(17)7H7 067 371 Aupholstery material (cloth)
F >> 7H-5-200 000
-BL1PR-N2M
2004.04 - 2005.05
(17)7H7 067 371 Fupholstery material (cloth)
F 7H-6-000 001>>
-BL1PR-N2M
2006.05 - 2009.05
(17)7H7 067 371 Bpadding cover (leather)-YD1PR-N7L
(17)7H7 067 371 Cupholstery material (cloth)
F >> 7H-5-200 000
-EV1PR-A8L+N2P
2001.05 - 2005.05
(17)7H7 067 371 Gupholstery material (cloth)
F 7H-6-000 001>>
-EV1PR-A8L+N2P
2006.05 - 2009.05
(17)7H7 067 371 Dupholstery material (cloth)
F >> 7H-5-200 000
-EV1PR-A8R+N2P
2001.05 - 2005.05
(17)7H7 067 371 Hupholstery material (cloth)
F 7H-6-000 001>>
-EV1PR-A8R+N2P
2006.05 - 2009.05
187H7 067 369 pocket1
18AN 90060201clamping washer6X13,52
(19)7H7 067 361 Brear panel for backrest1CALIFORNIA
197H7 067 361 Erear panel for backrest1CALIFORNIA
COMFORTLINE
20701 867 299 clip8
701867299 3U6artgrey2004.04 - 2009.05
213B0 867 334 grommet9
223B0 867 333 clip9
237H5 883 920 guide for head restraint, adjustable2CALIFORNIA
7H5883920 3U6artgrey2004.04 - 2009.05
247H5 883 920 Aguide with push button for adjustable head restraint2CALIFORNIA
7H5883920A 3U6artgrey2004.04 - 2009.05
257H7 067 421 rotary insert
support for head restraint
1CALIFORNIA
COMFORTLINE
267H7 067 401 Aadjuster (rake adjustment)
also use:
*>>7H-5-009001
7H7 067 547
1;2
27N 10620801oval head panel screw3,5X6,52
307H5 883 901 head restraint with cover, adjustable (cloth)2CALIFORNIA
7H5883901 PYLartgrey-BK,EV2004.04 - 2009.05
307H5 883 901 Ghead restraint with cover, adjustable (cloth)2CALIFORNIA
7H5883901G 80Uartgrey-BK,EV2009.05 - 2009.05
(30)7H7 883 901 Ahead restraint with cover, adjustable (cloth)2CALIFORNIA
COMFORTLINE
7H7883901A RFQpure beige/artgrey-BL2004.04 - 2009.05
(30)7H7 883 901 Ehead restraint with cover, adjustable (cloth)2CALIFORNIA
COMFORTLINE
7H7883901E PYLartgrey-EV2004.04 - 2009.05
(30)7H7 883 901 Bheadrest with cover (leather), adjustable2
7H7883901B RFVartgrey/pure beige-YD2004.04 - 2009.05
337H7 067 425 thrust piece
pressure spring
2CALIFORNIA
COMFORTLINE
34N 0124412retaining washer102
35N 90254701retaining washer8X0,502
377H7 067 079 ball pin2
387H7 885 585 bracket for guide1CALIFORNIA
40N 0133201spring pin4X144
42N 10692201hexagon socket flat head boltM4X42
43N 90085202clamping washer8X162
45N 90646201hexagon socket flat head boltM6X122CALIFORNIA
logo_en.svg
OEM catalogs
It’s a 2005 SE (doesn’t that show in my profile?).
I did find the schematics. Also another thread with pictures of the trim removed. I could use some advice on the best way to remove the trim, if there are any certain tricks.
Any use?
head restaints
F >> 7H-6-040 800
4seat belt guide
857-70,12
COMFORTLINE
6adjusting element
no replacement part
for this use:
7H7 098 3942
-7H7 098 394bowden cable
adjusting element
lowerX
7pin
no replacement part
not exchangeable
2
87H7 067 407pressure springlower2
97H7 067 406bowden cable
also use:
right lower
7H7 067 413
1;1
9A7H7 067 413connecting piece2
107H7 067 082gas filled strut1
117H7 067 547bowden cableupper2
14pin
no replacement part
not exchangeable
121X51,5
COMFORTLINE
F >> 7H-5-200 000
-BL1PR-N2M
2004.04 - 2005.05
F 7H-6-000 001>>
-BL1PR-N2M
2006.05 - 2009.05
F >> 7H-5-200 000
-EV1PR-A8L+N2P
2001.05 - 2005.05
F 7H-6-000 001>>
-EV1PR-A8L+N2P
2006.05 - 2009.05
F >> 7H-5-200 000
-EV1PR-A8R+N2P
2001.05 - 2005.05
F 7H-6-000 001>>
-EV1PR-A8R+N2P
2006.05 - 2009.05
187H7 067 369pocket1
COMFORTLINE
20701 867 299clip8
213B0 867 334grommet9
223B0 867 333clip9
237H5 883 920guide for head restraint, adjustable2CALIFORNIA
257H7 067 421rotary insert
1CALIFORNIA
COMFORTLINE
also use:
*>>7H-5-009001
7H7 067 547
1;2
307H5 883 901head restraint with cover, adjustable (cloth)2CALIFORNIA
COMFORTLINE
COMFORTLINE
337H7 067 425thrust piece
pressure spring
2CALIFORNIA
COMFORTLINE
377H7 067 079ball pin2
387H7 885 585bracket for guide1CALIFORNIA
logo_en.svg
OEM catalogs
Absolutely. There where two, now I’m certain which one. I found a Swiss website selling an aluminum version of the rake adjuster handle (no26). Very expensive. I would guess it’s the upper bowden cable (no11) I need to replace
I had to replace the plastic back plate on mine. Different model, but remove all visible screws. Use plastic trim tools to ease the panel around the edge and some significant force. I would get some replacement plastic fastners as they tend to break. Take your time.
Thanks. I have now managed to remove the upper part of the back panel trim and also the rake handle to confirm the upper bowden wire is cut off where it is connected to the handle ( se pic). The remains of the wire easily removable. To be able to unhinge the wire I need to remove more of the trim but there are 3 clips behind the pocket and in the bottom (not necessary to remove) that’s really stuck (se last pic). Any tricks before I break the panel in pieces?
You have to unscrew, easier said than done, that central section. The correct sized bit, or an Allen key, heated up and pushed in to melt the plastic. I’ve used that technique in the past on something similar.
Other than that, a trim tool to tease it out or a screw driver with tape around all but the end of the blade to avoid damage to surrounding trim.
After 2005 they changed the mechanism, mine is a 2006 and
to lower the bed I have a release strap which is between the base and the
back of the seat.
I'm sure it is the same function, just that yours has longer wires that extend up
the seat back.
It could be worth investigating if you could 'sort of' upgrade yours to the newer
system ?
Probably worth looking into.
Ah, thanks, so they can be unscrewed! I will give that a try tomorrow with a heated torx bit. I have a trim tool set.
It seem the bowden cable is out of production. That gives me another problem. Maybe @westfalia below has an idea.
back of the seat.
the seat back.
system ?
Thanks. The cable system has two parts, one upper (bowden cable) and one lower cable. If the lower is a generic construction maybe it’s doable. The upper bowden cable seem to be out of production, no where to find.
I'm sure the seat/bed is the same, we just need a parts diagram
from about 2007 onwards.
Hopefully you can then adapt the lower cables, connect them to a strap and glue the
old release back in place.
But it is such a simple construction. If I could just find any cable with a bowden end (bike cables?) and just tie it to the mechanism, that would probably work.
It seem the LLL parts have the cable in stock but the site won’t accept my registration.
Is this any use?
Surely the cables aren't hard to come by.
Is this any use?
Maybe not, but thanks. The end that goes into the release handle can be seen in the pic in my earlier post.
I managed to register an account at LLL Parts UK and I made a request if the cable will be back in stock again. I can always buy a complete new backrest for 780€ (in stock) or just the cable for 28 .
Ahh, I see.
Well good luck with the 28€ cable. :thumb
My rear seat has just been stuck in the down "bed" position and I was trying frantically to pull the centre strap and raise the seat back, but to no avail. The strap was trying to release the catches, but was only moving slightly and not enough to release the mechanism.
My solution was to put all my weight on the seat back and pull the strap, keep tension on the strap and then pull the seat back up into normal position.
This isn't a permanent fix and certainly needs looking into, to see why the strap isn't able to operate the release mechanism properly.
I had this once and it was due to something in the boot pressing hard against the seat back when it was folded down.
We had similar issue with our 2014 T5 Cali Ocean - seat in bed position wouldn't budge at all. Solution? Push down on the seat back whilst pulling up on the strap. You need to push down to free the locking latch. May help some people.
