Being terribly bright and clever.....
GrannyJen
GrannyJen
West Sussex
Cali now sold
When rinsing out a muddy tee shirt....
1: Boil kettle of water on sinkside hob.
2: Pour hot water over tee shirt returning kettle to fridgeside hob.
3: Rinse Tee shirt, lift out of bowl, pour rinsing water down sink and remove bowl so tee shirt can be wrung directly into sink.
4: Place bowl for convenience on sinkside hob whilst squeezing out tee shirt:
5: Hang tee shirt up.
6: Work out how to remove bowl after it had welded itself to very hot, recently used hob :oops:
Hmmmm.....is it the age ....?:Nailbiting
It's not you being a newbee , so ....
Did you get the bowl removed , the melted plastic ?
Pictures say more than 1000 words...
:D
Oh dear....
Hope you have a successful clean up.
Ease the bowl and cooker wire/bit/thingy up carefully and you have a bowl with legs?
Does it still hold water?
Upside down and it's a mug tree?
:cheers
re-heat bowl turn off gass scrap stuck bowl bits off while still hot with wooden spatular, well it works for my melted plastic place mat.
It’s useful, it will stop the bowl sliding off when you go round corners ;)
