briwy
So if you get a new bottle every time you go away you're going to waste an awful lot of expensive gas. Thsts why we carry a spare and use all the gas up. Scandinavia is the main problem for Camping Gaz supply.
That is the only way you can use every drop in your cylinder and the spare ensures you never run out. I went for the truma devise to give me an “early warning” to save weightSo if you get a new bottle every time you go away you're going to waste an awful lot of expensive gas. Thsts why we carry a spare and use all the gas up.
That makes sense, if you only have the van to burn the gas in.So if you get a new bottle every time you go away you're going to waste an awful lot of expensive gas. Thsts why we carry a spare and use all the gas up. Scandinavia is the main problem for Camping Gaz supply.
I get 45/50 days cooking every day and 4/6 kettle bottle a day if that helps.How quick are you guys getting through a bottle? I don't think I've ever used a whole one in a year. I keep a spare at home & swap depending on how long we are going to be away.
The current spare is almost empty - I use it for the BBQ at home, so will get that refilled & put in the van before the next long trip & then finish off the current van one using the BBQ.
Don’t be fooled.Looks like there are plenty in Europe?
Campingaz have updated the gas locator section of their .uk website.Good to read your different views and approaches, thanks. I may well just take a 904 as a spare and to fuel the bbq, though they seem tricky to get hold of - lots of places out of stock but they seem to have some here for £56!
I’d much rather monitor the level and schedule a refill when I’m close to empty though. This looks like a promising Bluetooth monitor, but I can’t work out how you power/charge it.
This video shows you round a Peugeot Symphony van fitted with a Gaslow system that sounds ideal - fill up across europe for €6. I called the U.K. office who say they don’t have a kit able to retrofit a California as the space in the water tank is too tight to take the pipe work/regulator.
Seemingly none further north though. Perhaps because you need propane in the cold?Campingaz have updated the gas locator section of their .uk website.
You can now search for retailers selling:
1. cartridges and refills
2. cartridges or refills
3. refills or (cartridges and refills)
4. Cartridges or (cartridges and refills)
Campingaz Gas Store Locator
Campingaz offers a uniquely large dealer network across Europe, guaranteeing you a widespread availability of our gas cylinders and gas cartridgeswww.campingaz.com
Below is a screenshot showing retailers selling refills [red] or (cartridges and refills) [grey].
Since I was last there, it seems that the Baltic States are beginning to sell refills, and they are widely available in Denmark.
You’ll also find in Norway/Sweden campsites have excellent cooking facilities for clients so you can always use their facilities when on-site and save your gas for off site use.Seemingly none further north though. Perhaps because you need propane in the cold?
So if I’m heading north of Denmark, fir more than a month (not until I retire...) I’ll need 2 full bottles I suppose, otherwise one 907 should do it
That’s what we do.Someone once suggested, and I have since followed the suggestion, of converting your Cadac (if you use one of course!) to use the same gas. Therefore you always have two until one is empty, buying you time to find a refill.
Yes and you can strech it to 200 if you turn the gas off when turning the Bacon over! I have the data and waistline to prove it.907's are available across the Channel unless you are going on
a massive trip to far out places, a full bottle should do you.
Just weigh what you have or get a full one before the expedition.
A full one should be good for about 174 bacon buttys.
Yes I use the 904 for the bbq too, saves hauling the 907 outCarry a 904 and a 907. Exchanged on the Continent when required.
Yeah I tried the luggage scale and failed as it has an auto hold function and I can’t turn it off.I have a standard handheld luggage scale from Amazon in the van
remember getting it for about 5 GBP about 2 years ago.
I have a manual version, little to go wrong.Yeah I tried the luggage scale and failed as it has an auto hold function and I can’t turn it off.
Looking for one to sit on the floor and put the bottle on top
borrow your wife/partner's weighing scaleYeah I tried the luggage scale and failed as it has an auto hold function and I can’t turn it off.
