Remote batteries, so I was told, should last about 4 years.I have been out , jumping up and down, and making all sorts of noise.
And you are right Welsh gas.......sort of.
One push on the key, and alarm sounds after 30 mins
Two pushes on mine doesn't always make the doors clunk....perhaps a low battery....but when I get the extra clunk, and the locks rise a little, presumably removing safelock....then no alarm, even with crazy jumping.
The alarm does sound if you open the door
To add to the senarios
If you open front door, take key out, and push the pillar button, which turns yellow
Then you can single lock...so safelock on, ...and no alarm jumping, but alarm if you open a door from the inside
Final senario is to lock using the button on the door
Then no alarm, and you can open from the inside, with no alarm, but not from the outside....
So thanks Welsh Gas, I think I understand it. You need to go and play Old Sid
And I need to change my remote batteries
