H
haydnw2
Whilst attempting to swap the festoon bulb in the boot light for an LED one, I've managed to stop it working. The new LED bulb doesn't work either way around, nor does the original bulb (filament is still OK). My first thought is to check the fuse, but I have no idea which one it is! Despite combing the Resources section, I can't find a fuse diagram for a late T5.1 SE (registered April 2015). I'm also slightly bemused that everything else I've tested seems to work, but I can't believe that one boot light has its own fuse. The layout diagram for the Beach suggests that the "luggage compartment lights" should share a fuse with "front and rear interior lights" and "illuminated sill panel trim", but all of those are still working. I've checked with a multimeter and there's no voltage across the bulb terminals. The check was done directly after unlocking the vehicle and opening the boot, so it shouldn't have timed out due to the 10-minute rule. The plug in the wardrobe seems securely attached to the light fitting.
Can anyone offer any insight as to which fuse I should be checking, or any other avenues to explore, please? It was only supposed to be a five-minute job!
