nev7n
- Messages
- 9
- Location
- Cornwall, UK
Took the T4 to the tip to drop off some recycling, went to start it to leave and....nothing. The ignition didn't feel right so I guessed it was the new ignition switch I'd fitted recently. The tip was just about to close so I got a free push off the premises by the workers at the tip so they could lock up and go home.
An hour later and the van was loaded up on the recovery truck for the journey home.
[album]1255[/album]
The recovery driver wasn't sure if we'd fit under the low bridge with the high-top so we took the scenic route.
Checked the ignition switch at home by taking it out and turning it manually with a screwdriver - no problem there. However, feeling in the back of the ignition barrel the metal tab that turns the switch was missing. I guess the new ignition switch being a bit stiffer than the old one finally made the tab give in to metal fatigue.
Got a new ignition barrel from Just Kampers: http://www.justkampers.com/1h0-905-855-a-ignition-barrel-for-vw-t4-1990-2003.html. You have to drill a small hole in the casing to release the ignition barrel, I'm planning to fill it with a little metal filler at some point to make it secure again. All up and running again now .
Fitted a new courtesy light switch to the drivers door at the same time, 5 minute job and good to have the light come on automatically with the short winter days.
[album]1255[/album]
