Broken sliding door catch
Celia Vanchez
Celia Vanchez
Jersey
T6.1 Coast 199
Just back from a trip during which the catch to the sliding door below the burner was broken meaning the door slides during transit. I think superglue will be insufficient to repair the catch which fits into the small hole on the left of the frame. Does anyone have possible solutions or does it mean replacement panel? Thank you in advance for any feedback
There’s another post today from another member having the same problem - it is a very common issue. Yes spares are available - including the club shop.
Here are some other threads regarding this …
Just had ours replaced under warranty so be worth checking before buying a replacement.
I just needed ours done before we went away this week so decided just to buy one. In truth it was our fault it broke - that and a crazy design !
Ours also broke. Had it fixed under warranty. While in a coolant leak was diagnosed + due to a part being on a back order our van was in for a month…….
Hi
Can you tell me where you bought the part please.
Diane
post a picture and I'll try and identify manufacturer and part number
Put the part number into google and see if anywhere has it, should be around £25 ish
Ok just got the part any ideas how to fit it ?
