It will cost you more to buy and use more fuel.
But you are less likely to get stuck in a muddy field and it will handle a little better. Also less likely to lose traction when you need to exit a side road in a hurry!
Having had both, the two wheel drive one is fine but when I change ours it will preferably be a 4motion again. The way things are with supplies at the moment we’d be lucky to get anything!
I guess the one to go for (assuming it is within budget) would be the T6 then, if you can find one at the right spec and price.Hi I have also owned both 2 and 4motion, I will be buying a 4motion but the question is weather to buy a T5 or T6 I did try to do it as 2 separate threads but the powers that be put them together.
Re your other observation about 2016/2017 campers, maybe the dealers have stocked up on demos. I don't think many genuine private buyers would sell their vans on so quickly.
Many of the 17 plates in dealers are ex vw management vehicles (KT (and KX?).... reg numbers show VW Mgt). They have recently been released hence the 'flood' of them. I suspect a similar spike is seen every 6 months.
I don’t blame you. Unfortunately we are just punters to dealers like that.I am not happy with the situation
Suggest you post up your experience on the dealer reviews section. I hope it’s no one near me!
I wouldn´t like to sell you a car.
Maybe the dealer picked up the same vibe.
no offence.
Ours has never used any between services, I think maybe it was a problem with the earlier ones?Hi Motacyclist how have you found your 180 engine I have heard and read that they can use a lot of oil ?
Correct.Ok thanks
I think that I was told the ones between 2010 and 2012
You need to do some more research on that. There are separate threads on the subject, which will also link you to a Facebook group.Ok thanks
Correct.
I'm now at 64,000 miles in just over 3 yrs. Annual service at around 20,000 miles with the Oil Service data showing at least another 6,000 miles. Have used 1 L of oil in Year 1, 2 and 3 as top up. I do some long distance travelling and rarely do less than 50 miles/trip.
1L/20,000 miles.Hi WG do you mean in 3 years you used 1L or 1 per year
At the moment I have got a t5 2.5 tdi 4motion kombi never put any oil in it for 3 years as a top up just oil changes.
But I have got another car what uses about 1L every 1000 miles or so if driven quite hard but it is a performance car and it is normal for them to do that.
1L/20,000 miles.
I know of NO modern engine that does not use some oil on a high speed long run. When the engine is upto temperature some oil vaporises and that is one of the reasons you have Crank Case ventilation where the Crank Case is ventilated into the Intake manifold in some way so any oil vapour will be extracted and burnt. This is normal. Obviously if you do 10,000 miles/year and have an oil change annually it would appear you use no oil. If you do short low speed runs you won't register any oil use. It really depends on your usage. When touring I tend to like to get to my ultimate destination quickly so 400 miles at 70-80 mph on continental autoroutes is not uncommon. That warms the engine up properly. I've also never noticed a DPF Regen during my ownership.
My RX8 used to use 1L/1000 miles and only had a 2.5L capacity so this consumption is more than acceptable.
The issue (when it occurs) is not to do with the cost of the oil, it's that is that they go from 'full oil' to 'oil warning light' in the time it takes to use a tank of fuel. Apart from that being intolerable, that consumed oil is finding its way into the emissions control equipment which gunk up and bring on warning lights / bring you to a stop. If this happens to your engine out of warranty, it's a £7k bill.
I know of two effected 4x4 180's that their owners have chosen to part ex into dealers without declaring the problem. One is still for sale at an 'attractive' price, so be aware and do understand 'egr suffixes' before buying one.
I don't want to open up the debate again, but couldn't leave it there.
