Tommy Gun
VW & BBQ Boy
I think the confusion is arising because the T5 range (and presumably the T6 as the mechanicals don't appear to have changed much) actually has two differentials. Or, I guess three really as the front driven axle must also have one.
The two extra ones on the 4Motion appear to be as follows.
One is the centre one which is standard on the 4Motion and is electronically controlled without any driver input that decides where to send the drive to for the best traction.
The second differential is the one on the rear axle which is the one that now seems (used to be standard) to be the optional extra. This is operated by the driver with the button on the dash and locks the rear diff so that both rear wheels turn at the same rate. Hence it should not be used at speed and only where the conditions merit it's use.
This may help explain it.
http://www.volkswagen.co.uk/technology/transmissions-and-drivetrains/4motion
To confuse further there is the already mentioned standard EDL system on two wheel and 4wd which again uses the brake on individual wheels to get the best traction. This only works up certain speeds to prevent overheating. 25mph on 2wd and 50mph on 4wd.
All very complicated, god help us if it goes wrong.
Briwy,
Thanks for the detailed reponse. The extra diff on the rear axle would justify & explain the £575 price tag.
Nice one. Cheers
