Cable via firewall - best access from engine bay to cabin
  • Thread starter Californication69
  • Start date
Californication69
Californication69
Bill
UK
Looking to buy
As per the thread title.
what’s the best access through the firewall bulkhead ?
Is it still the same Gromit behind battery or is there somewhere else to pop 2 or 4 gauge 14 wires through ?
TIA
Hoping someone has some useful information on how I can get some cables for lightbar into the cabin from the engine bay ?
I might have to grab a 16mm flat drill and just cut me a new hole ;)
Any use? 12 or 17.
Remove the battery and the cover to the E-Box and you can follow the main loom.
Be careful not to use the grommet that is actually a drain.
Not really wanting to remove the battery. Does it not cause strange software gremlins to creep in ?
And thank you for the heads up on the drain grommets. Had enough of those pesky things whilst fixing a golf sunroof blockage that had 3 inches of water inside the Sons car! I’ve heard the California has right angle connectors at the roof level, not easily accessible, so I most certainly do not want to pull or poke a hole in those drain tubes & dislodge ! Thank you @Loz
Do we have access to system diagrams like on the T6 forum? Are they in the VIP section ?
