jamesC
Hi,
I have a small, but concerning issue with my non-electric pop-roof, The vehicle is absolutely brand new and I noticed this the first time I ever had cause to put the roof down.
On the Beach there is a small fork shaped metal collector plate mounted on the fixed part of the roof around two thirds of the way back which as the roof closes meets with a small bracket mounted on the pop part of the roof.
The alignment of these two parts is slightly out on my near side and this stops me from closing the roof (the hinged clasp inside the vehicle does not meet up correctly). Upon investigation I realised this and now just give the roof a slight pull to the right from inside as I lower it, and it closes, all is fine.
I have also noticed even when correctly located the fit of the internal clasp is not quite as precise and aligned on the near side clasp as it is on the off side.
My question to others is, do I complain and get this sorted under warranty... which I would rather avoid because in my mind this involves a mechanic trying to bend a piece of my Cali to fix the problem, or live with the problem??
Do any other Beach or SE owners have any similar problems??
Any advice before I call my dealer would be appreciated.
