Assume this would be off hookup? So basically using leisure batteries to step up to mains ac then the CTEK BACK TO 12v. Probably not the most efficient route but can’t see why not, so long as the CTEK doesn’t overload the inverter.Just wondering if I were to unintentionally flatten my engine battery what is to stop me from running a CTEK charger from the inverter socket to charge the engine battery?
Too much time on my hands!!
I get you, but if you are on day 3 of your camp won't the leisure batters be too low to achieve this?I am only thinking that if I were to flatten the engine with no hook up then to get it started in emergency situation .
I guess once engine started then all batteries will charge on the journey home then plug it in
