Can recommend below; not sure regarding the size as we have a T5.1, but they have measurements on the website & some are tapered at the bottom so should suit most cupholders:Hi there
has anyone found a coffee cup that fits the cup holders on the T6.1. Very annoying having to use disposable ones that don’t fit
Thanks, I’ll give those a goCan recommend below; not sure regarding the size as we have a T5.1, but they have measurements on the website & some are tapered at the bottom so should suit most cupholders:
DRINKWARE
The YETI Rambler family is tough as hell, and will keep your drinks as cold (or hot) as science allows. Find the drinkware for your next adventure.uk.yeti.com
I wouldn’t use these in your 6.1 when it arrives unless you don’t mind scratching the plastic. They have a flat metal edge on the base which marks the cup holder when it goes in. Works OK but looks unsightly. I speak from experience…Got ours from TK Max used them in the T6 fitted well and kept the drinks hot or cold.
Noted thank youI wouldn’t use these in your 6.1 when it arrives unless you don’t mind scratching the plastic. They have a flat metal edge on the base which marks the cup holder when it goes in. Works OK but looks unsightly. I speak from experience…
We also couldn’t find a Yeti that worked well, thus ended up with the Le Creuset ones which we have found to be really good.
All yeti ones come with great lid unless you are looking a the tumblers for wine.Tried a couple of yetis in the dash holders. The 10oz tumbler was far too small. The 16oz pint didn’t quite go all the way down and personally thought it restricted view too much. It also didn’t come with a lid although I think you can buy one seperately. Ended up going with the hydro flask 16oz tumbler which fits with a couple of mm to spare and isn‘t quite as tall. Pretty inflexible holders as ideally you want a perfect fit.
Hi, We have the same problem and after reading all the responses and having to return a few cups that we ordered as a result, I’m not sure if all T6.1’s are the same or indeed if people are happy with their cups falling out when you turn a bend (as ours do). We have a California Ocean 2016 plate, which I thought was a 6.1, but maybe not…. Either way, we’ve been looking for cups that fit the pull-out holder next to the gear stick and have struggled. Neither our Bodum cups nor recently returned Le Creuset cups fit (due to the 7cm diameter base), and neither do most travel mugs/cups which you can pick-up on the high street or on-line. The cups which I needed required a 6.5cm diameter base, tapering to 7cm, 4.5cm up from the base. The ones we’ve seen, measured (using a digital calliper) and ordered, which fit are the Thermos, ThermoCafe, double walled, mugs (~£10-13) but Millets also sells a Eurohike travel mug (currently £9, down from £18) which measures correctly and would appear to be fit for purpose (but we’ve not bought). Hope this and the attached images help Will update when the cups arrive and IF they are fit for purpose…….Hi there
