bangorlad
Been doing lots of searches and forum reading in order to avoid our Cali suffering winter ailments and am a little confused when it comes to maintaining the leisure (mainly) batteries.
From all the posts I'm pretty much convinced spending £70 or so on a Ctek is a good investment but of all the threads I've only seen one that mentions connecting this via an 'open' 12v socket is not recommended in the manual. I've confirmed this and it's pretty adamant you shouldn't feed electric current *into* the sockets, but everyone seems to do this and Ctek even supply adaptors for the purpose. Am I to understand this is just VW covering their backsides but if something goes wrong with the electrics they won't want to know?
Is an alternative to connect directly to one of the LBs? Are they both simply in parallel and will both be charged? Up to now the van is driven fairly regularly but often shortish trips but the batteries seem good with monthly c12 hour hook-ups in addition. Presumably a MXS 5 will be pumping up to 5A into the 12v socket circuitry and I don't to want to stress or damage anything.
Thanks,
Stew
Thanks,
Stew
