lovecalitravelbe
Hi all!
We recently bought a new VW California (2023 model) but we're having lot's of issues with the control panel of the camper and I'm wondering if someone here experienced the same issues or maybe has a clue of what the problem can be.
Next Tuesday the Cali is going to a VW dealer, but the reseller I bought it from mentioned that VW needs to experience the problems themselves before they can solve it, and the issue usually only pops-up a after a longer drive, or in the morning after using the fridge.
I have attached some pictures of the errors I am seeing. And here is a movie of the alarm going off and control panel not responding. Sometimes I'm not seeing the errors as the screen stays black and unresponsive. We also tried resetting the Cali, and that only temporarly solved the issue.
Hoping to learn something more here so I can relay that input to the dealer.
Thanks! And wishing you happy adventures.
- It started out while driving on the motorway, suddenly the pop-up roof alarm went off and a pop-up roof error showed, I had to remove the fuse of the control panel (the one under the driver's seat) to silence the alarm. Since that first occurance this issue, and other ones, occur regularly.
- When coming back to the Cali, sometimes the control panel stays black and does not come on, and I have to remove the same fuse and wait a while before the control panel functions again. When this happens the fridge stopped working also. Sometimes a brief error message flashes when touching the button, and then the control panel stays black and unresponsive. The error message is ususally the pop-up roof error or the fridge, but other times also errors are displayed on the watertanks.
- There seem to be more regular problems when using the fridge, but the issue is also there when not using the fridge.
