Control panel repaired - reinstalled now have roof error 1000
Al1992
Al1992
Somerset
T5 SE 130
Hi all,
Found topics on roof error 1000 and the requirement for changing the sensors to overcome the fault code. However, I am having a slightly different experience. I have just received my control unit back from repair (the dreaded lines on the display) and after reinstalling the control unit, it is now displaying the roof error 1000 in the hidden menu and I can no longer open/close the roof using the control panel.
It was all completely fine before the unit was removed and I have unplugged it all and reinstalled a second time just to make sure all the plugs where fully inserted.
Has anyone else experienced this issue, if so how did you overcome it? My van is a 2005 for information.
Thanks,
Al
Hi all,
Thanks,
Al
This has now happened on mine...exactly the same. Sent the control panel for repair, the knob was replaced. First time I came to use the van I was in France and the knob wouldn't engage, neither rotating, or pressing in. I had to use a small screwdriver to scroll through the menu's and select.
Now back home...it's saying the roof is up, with error code 1000.
I will be sending the control unit back, as the so-called repair is still under a one year warranty.
Did you get your issue sorted?
