Lesley Dale
Anastasia
Hi.... I have read conflicting answers as to what your tyre pressure should be on a 2018 California Ocean TDI BMT so I am a little confused. The warning light (!) came up on my dashboard, after a long journey, so I checked my tyres and the Front nearside was registering 48.1 psi & the others 51psi - So I checked the Tyre Pressure information on the Drivers door for 235/55 R17 300X - and that says 45/45 psi.
They are Bridgestone's all round and recently had two new ones fitted on the front by Selecta Tyre, the wheels balanced & the geometry adjusted rear & front. So I would presume that they would have set them at the correct pressure. To make sure I put in the correct pressure I even checked the internet which then ranged from 44 psi to 54 psi - also putting more air in the front than the back or vice-verse.... Even more confusion!! Can anyone please tell me what the CORRECT tyre pressure should be for my vehicle!
I'm generally the only one in the Vehicle with my two small dogs, obviously all set to go travelling with all the gear.... So would it be classed as "Laden" !!!
