Cruise control stopped working - 08 174 cali
cheekymonkey
cheekymonkey
Hi Guys,
Cruise control jsut stopped working for no reason - have taken apart stick & checked connections they are all clean.
Can anyone suggest any tests or checks?
Does anyone know which fuse (and location of fuse) runs CC as nothing in handbooks
Could be a faulty clutch position sender. Check to see what the engine can rev up to in neutral and also when you have the clutch pedal depressed and let us know the outcomes.
cheers
Sounds like it is faulty. When the clutch pedal is not depressed and in neitral it should rev above 3000 rpm. Not difficult to replace and dot not require any coding afterwards either.
cheers
Thanks Alex was the eBay link above the right product??
Not sure on engine number reference
Looks like it. Best thing to do would be to call our parts department on 01403 839640 and get the price and avaiability. We will also post it to you as well!
cheers
And don't forget if you sign up to VIP you will also save 10% on the price :thumb
All ordered ill let you know if that solves it
Thanks again
Hi Guys,
I have this problem today in France. I know it’s a long time ago! Was this the answer. Did you get it fixed? Thanks. Peter
Unfortunately I don’t think you will be getting a reply. @cheekymonkey hasn’t been seen since 2015.
