Raggedroy
Does anyone use a dash cam? What do you recommend, where is it fitted and where did you pick up power?
Cheers.
Cheers.
Try the DOD LS430W with built in GPS, speed/time/plate number, all recorded (remember this if you need to produce it as evidence) or you can knock them out if you wish, they will be recorded to the SD card, I leave mine on I think it makes me a better driver (speedwise) I wish I hadn't said that. Supplied with cables, two cam holders(one suction one permanent) the cam can be removed from either with the flick of the thumb, mount it behind the rear view (passenger side) but not on the window/mat or it might interfere with the sensors in the mirror, route the cable between h/lining & screen to the door pillar then between the dash & screen to the centre 12v supply. PHEW! hope this in NOT too longwinded a reply.
I bought the transcend drivepro 200 on a whim the other day and have been surprised how well thought out it is.... The only slight issues are that the windscreen mount is permanent, not just a sucker and it has no GPS or Speed Camera's
Overall though, seems a clever, well designer bit of kit!!
Indeed... I should have clarified, it does not come with one which I think is odd.Hi James,
It can be used with a suction mount...
http://www.amazon.co.uk/dp/B00JY6W8YM/?tag=eliteelect-21
regards,
Mark
I've been thinking about getting a dash cam for a while now and this looks just the job so have just ordered the 32gb one, cheers for the link kev
Run the cable down to the fuse panel under the gear stick and use a piggyback fuse.I have dash cam that I want to connect to ignition controlled power supply.
A part from the cigar lighter which is live all the time, does any one know where I can pick up ignition controlled supply
Why do you want ignition controlled wire? It is quite handy the camera can film if your car gets hit while parking?
I have mine hardwired in the controllable like @Loz described in an earlier thread. If the battery gets low, the camera stops automatically. Very neat installation.
