Dashboard screen display menu
PaulBishop
PaulBishop
Cardiff
T5 SE 180
I'm having problems changing the display on the menu screen between the revs & speedo. It currently shows the MFD screen, but I'd like to view the Vehicle status screen and having followed the manual instructions cannot change the screen.
Can someone point me in the right direction.
I have the windscreen wiper controls only, not the mutli function steering wheel.
There is 2 buttons on the end of the wiper stalk and one underneath it.
Hold your finger on the bottom one of two for about 3 seconds, the middle screen will then change to show several options. Move up or down this screen by quickly pressing one of the two end buttons. Once on the option you want press the button underneath the stalk to accept.
Hope this helps
It works by holding the upper one too, as long as its on the end of the stalk it will bring up the menu.
If it doesn't work with the buttons as above it might need recoding.
Just had this problem on ours and dealer had to sort it.
Thanks everyone I'll give it a try.
Paul
