Sp0_0k
- Messages
- 1,247
- Vehicle
- T6 Beach 4Motion
You should drive more untill it is under warranty we are about to hit 70k km on 2nd year.It's coming up to two years old with 16500 miles
You may be right but it was certainly the case with VWs a few years ago that opening the drivers door started the preheat sequence. It was designed to cut down the time taken for the glow plugs to reach optimum temperature for starting. Older diesels used to take ages toI think it should preheat when ignition is on. Even that sign is glowing showing that and then turns off. Even if you try to start there will be a delay untill it properly preheats.
Funny that so many people aren't even aware they have this issue until decent cold hit Europe.
I had it a lot due to lots of travels to the mountains.
Wow, you're getting maximum use out of your Cali.You should drive more untill it is under warranty we are about to hit 70k km on 2nd year.
Maybe coil flashes because you started it to early before letting coil light go out. I always thought glow plugs are to aid derv engines when they get older. I wasn’t aware that new engines required pre heat unless it gets seriously cold, -10 below for example.
I stand to be corrected but as far as I am aware all diesel engines whether old or new have glow plugs to aid cold starting. I am no mechanic but my understanding has always been that in principal the diesel engine works by compressing the metered injected diesel fuel/air mixture within the cylinder to such an extent that the heat generated in this process is sufficient to self ignite the fuel/air mix. Therefore diesels don't require ingnition systems like petrol engines have.I can’t understand why the tail flashes with DPF problem. Surely the DPF light should flash. Maybe coil flashes because you started it to early before letting coil light go out. I always thought glow plugs are to aid derv engines when they get older. I wasn’t aware that new engines required pre heat unless it gets seriously cold, -10 below for example.
That's very interesting. It was exceptionally cold this morning but from what you've said the starter motor wouldn't have activated if the glow plugs weren't hot enough, so bang goes that theory.The starter motor won't operate until the coil light goes out ,so it cant be because of starting it too early.
All Diesels (except some chryslers that preheat the air) still use glow plugs, the only difference on a modern diesel is that the glow plugs are very quick to heat up, so its only when it is very cold that there is any sort of delay.
The plugs stay hot in operation for up to 5 minutes from a cold start & this is specifically in order to keep the emissions down & keep the quantity of soot that reaches the DPF to a minimum.
If there is a problem with the DPF it could be that one or more glow plugs have actually failed, with one out you probably wouldn't notice the difference. The TD5 engines fitted to Landrover discos & defenders were 5 cylinder engines with only 4 glow plugs & always ran a bit lumpy for the first few minutes in the cold.
The only external sign could be a bit of smoke from the exhaust when starting. Two out would make starting harder, four out & it wouldn't start at all.
From the number of posts this would seem to be a common issue in cold weather.I think the key bit is:
"The plugs stay hot in operation for up to 5 minutes from a cold start & this is specifically in order to keep the emissions down & keep the quantity of soot that reaches the DPF to a minimum."
Its the only link between Glow plugs & the DPF so one dodgy glow plug = gunged up DPF = Flashing lights ?
Similar story - no error code, engine management light on. Light switched off by another garage but came back on again.warning light and no error code generated?
As long as the problem has been registered with VW before the Warranty ends it should not be too problematic if it recurs.Thanks for the advice. The light is no longer light (it is fine after stopping and restarting the engine). and the garage state there is no fault code they can investigate. They have already changed some detectors and updated the EMS. So if I leave it with them am sure they are not going to do anything until the light comes back on again - seems to happen about once a month...not sure I can leave it with them.
I had this light appear in the middle of Spain last July. The Cali was cruising and suddenly went into limp mode. New turbo was diagnosed and fitted. Strangely, the light appeared again in exactly the same place on my return from Portugal a couple of months later. Eventually towed back to Bristol and a new intercooler fitted! On our latest trip we had fumes in the cab and Heritage vw are sorting under warranty and have it for 3 days. I’m sure, once back it’ll be amazing again. I’d get it checked for peace of mind.
Don’t think so. It ran very poorly from having a new turbo fitted and the intercooler was leaking oil. Towed back to Uk. New intercooler fitted an that side of things good. Currently in main dealers for a leak from manifold blowing fumes into cab.For the light to come on in exactly the same place is too much of a coincidence. This sounds like it could possibly be the result of external influences, such as electromagnetic interference for example.
Tried disabling it, as all my errors happened on cold runs. Still it happens, goes in a limp mode right away.It does seem to be a story of cold engine , going downhill and coasting that could be the trigger. I have turned it off for now. No light so far.
