Normally the VW part number is stamped on the relevant part.Hi, can anyone tell me what part number I need to look for to replace a diesel heater plastic cover for California SE, please?
Thank you!
Thank you, will have a look!Normally the VW part number is stamped on the relevant part.
If the part number on the one fitted is evident on the part , that will be correct@Perfectos @WelshGas Thank guys. I think I found it - 7e0825208
However, when I search for it - I only get results for t6, mine is t5.1. Are they the same?
Thank you!If the part number on the one fitted is evident on the part , that will be correct
they are all very similar, sometimes there is a suffix update such as t6 where heat shields were removed to save money! But in general the under trays are very similar across the range
