D
Dizzy
After much searching and reading articles we decided to not go with purpose made topper, mainly because the missus wanted something a bit thicker then 5cm (after trying our Emma 5cm topper). But also cos i thought they were robbing level prices !
So we plumped for an Ikea Tussoy (Standard size) which was 8cm thick and had a pretty nice padded cover on it which could be unzipped. 129 quid. The foam is pretty high density.
Obviously this wasn’t the correct shape for Dizzy so we set about disassembling, resizing and remaking the zip cover.
What a learning experience !
Some handy hints if you are going to attempt this.
First outing this weekend – will report back !
- Use either a purpose made hot wire foam cutter or an electric kitchen knife to cut the foam (we used the latter as we had one and it worked a treat)
- When you measure the material for reassembly take into account the added zip width if you don’t use a concealed zipper foot on your sewing machine. Ours wasnt as snug as we wanted but its ok.
- Use strong polyester thread, ours was pretty thick but ok for a bog standard 15+ yo Janome sewing machine.
- Take your time doing the template on a flat surface, we used our kitchen table
- Practice sewing in a zip into some spare material if you haven’t done it before
- Make sure you hem the trimmed mattress cover before you attempt to sew in the zip
- We tacked the zip into the remade cover before going at it with the machine, I think if we were more skilled this wouldn’t be necessary !
