YesWill they fit a t6.1 forgot to put the .1 in
What about an 07 T5 ?
Wan't them but appreciate advice/guidance from people on here.
I agree the ClimAirs are good. You can have the windows down a couple of inches and nobody can see the windows are open. Good for stealth campingFitted ClimAir "clear" to our T6.1.but also OK for T 6.
Good quality, small screw no problem, don't obscure view, easy to fit.
Bought them direct from ClimaAir,.The guy there was very helpful.
Recommend, give them a ring.
Good idea!No need to use the grub screw. The fit is tight enough to secure them and for a little extra security I used a strip of double sided 3M foam tape. 18 months later, no issues.
And just to be clear the tape was applied to the underside of the metal plate where the grub screw goes and not on the deflector itself.Good idea!
If still available, Would they fit a T5 if selling how much including postage.I have a pair of new, unused ClimAirs if that’s what you decide.
