I don’t bother too much about the gap. See pic below; this gives better access and a larger covered area. Stake out the wind out awning and it’s very stable.Hi
we have a Vango drive away awning connected by the figure of 8 kit.
What do others do about the gap at the top between the van and awning (see picture attached).
thanksView attachment 64659
If the awning was tight to the van it would rub on the panel and potentially cause damage when th3 awning moves (as it should do) in the wind, pegging the bottom, near the front wheel, close to the van will ensure a tighter fit, sliding the awning to the end of the wind out will help close up the visual gap the sliding door, If the weather is good I set mine up away from the van and use the wind out to extend the living space by a couple of meters, with a couple of tarps either side to close up the openness caused by setting up away from the van (Similar to Jodalo + 2 tarps) In bad weather set up as you have but put the plastic Kador strips on the top edge of the wind out awning flap, then wind the awning back against the casing to secure the plastic strips, this gives better tension to the tunnel and a little more height.Hi
Yes, I always position the awning with open door and then peg the rear first before the front.Use the figure 8 attachment. But unwind and slacken the rail awning about 1 foot.
Then once the drive away awning is in position, then wind in the rail awning so that you have a good fit.
Drive away awnings do take a few goes to get right for you, so be patient and retry until you have it right.
Also, be prepared to adjust where the driveaway awning is positioned in relation to the main door.
I then use a bit of rope to mark where the wheels should be positioned (approximately) when you do drive away and return.
We have the wind out, wound out too and then connect the driveaway to that. Also means you don't have to be in the perfect position when you return from driving away, just straight.
For me, why don't you just simply peg out the bottom closer to the front tyre, and then the gap won't be thereHi
