Driveway drain cover
MDY__________
MDY__________
UK
Grand California 680
Oops. Look what my 680 did.
I need a new drain inspection cover to fit a 320mm square base.
For reasons I grasp only vaguely, the force exerted by a braking vehicle wheel is much greater than half the axle load. So I think I need something rated for 10T. Maybe more.
Anyone know for sure?
And if that's the case, I can't find anything suitable. Either the load capacity is too low or the footprint is too big.
Perhaps I need the whole thing, chamber and all, pulled up and replaced.
I can't avoid driving over the thing. It's in exactly the wrong place.
Has anyone solved a similar problem?
How about a (5mm?) 600 x 600 steel plate over that? Easy and cheap from a local metal worker.
That is a proprietary cover manufactured by Osma , available from builders merch or Wickes. You can get medium duty (12.5 tonne rating ) B125 rating
have a look at the Osma products or replace with similar either “poly pipe” or “Clark ”
shop around for best price
you will probably need to replace the frame if you choose to get a different make
edit: the standard one you have is rated to 1.5 tonne !
edit: no need to replace the chamber & base (if installed correctly) just make sure the new cover frame new is bedded into a strong concrete bed
edit: check the pipe diameter, it should be 100mm and the new frame should be suitable for the correct size pipe , the one below is representative , not a recommendation of a product.
gclid=CjwKCAiA7vWcBhBUEiwAXieItoc5wegikVi9BBSDJabNkqu7SlHMP4jSNGUKYsxbosBji8dzgQ6JWBoC6_EQAvD_BwE
