Perfectos
Run the A/c when in the van Driving, the A/C will remove an amount of moisture via normal operatin.
also when parked up / at home, whilst the weather is not raining, open all doors and the tailgate for an hour, believe it or not the outside air will have less moisture in it than inside your van, the result is the moisture in your van equalises with the ambient outside moisture in the air. (Exactly the same principle when you hang washing out)
