Electric side door rubbing rear arch
Daniel Roberts
Daniel Roberts
Stockport
T6 Beach 150
Hi all, has anybody come across an issue with the side door rubbing the rear quarter panel, predominantly the arch eveytime it closes. Its like the door runners jump slightly when closing?
Looking to see if there is a fix, or if VWCommercials have stepped in to sort?
Sent from my SM-G998B using Tapatalk
Hi + Daniel Roberts, if you type something like sliding door rubbing into the "search forums" function at the top of the page you will find lots of discussion about what is a common problem and how to fix it.
Edit: Welsh Gas beat me to it.
Loads of previous info covering this issue. Use the "search forums" function under the header at the top of the page.
Check the alignment of your door against the body shell, check all panel gaps etc.
the sliding door can be adjusted
