ArunAlec
Thanks for the info.Continued...
Once removed - mind the cable end does not flick off into an eye - you can see the drive motor:
So pop the cover off minus the pulleys. I did not but you can of course isolate the power to the motor to fully incapacitate it but it no longer has any connection to the door mechanism so will simply rotate freely and then stop if activated by the remote control accidently. To disable the dash switch you need to add a jumper across the terminals shown:
That's it. AFAIK the door tracks and major mechanical parts are the same and once you have removed the drag from the cable/motor then to operate the door in fully manual mode is a joy to behold (especially if you have been fighting the thing for more than a month previously!). It feels like every other manual VW van door I have ever used.
Anyone considering doing might want to look at YouTube. There's are good video of a mechanic replacing the cable drive. It does give a good few tips on removal of the side panel.
