Electric sliding door - manual operation
CampervanTime
CampervanTime
Melton Mowbray, Leicestershire, UK
Westy Sven Hedin
Hi everyone
On the T6 / T6.1, if you have the electric sliding door option and set it to manual, does it still power latch closed the last few mm when you pull it shut?
Hi everyone
We have a 6.1 "standard" door. Virtually silent. It closes the last few mm. My 6 year old daughter can open and close the door with ease.
Hi everyone
You have to push it closed and then the electric latch will engage.
Didn't know about this. Where is the button/switch located? (Yes I know it's in the manual but that's probably down the back of the sofa)
On the T5 it’s on dash to the left of steering column with the switch to open/close the door. When in manual mode the door is very heavy to slide by hand but doesn’t make that annoying bleep!
