Electric Socket
K
Kaybee
Newent
Hello
Advice please, I've just done my first overnight trip for eons. I was hooked up to mains electric. The regular socket on the right of the kitchen unit ( behind passenger chair) that I'd hope to use for a kettle/ my laptop was not working. The van was new to me before lockdown so I don't know if it ever has. Any suggestions? Thanks
Have you checked the breaker in the aft wardrobe above the gas cylinder?
Thank you, in the manule it shows that slightly pushed down, but its hard to see. I can't make it budge. Does it?
The lever should move freely up and down.
Up for Power On. The indicator changes colour.
Breakers are always designed to be 'off' when down. Sometimes they are hard to push up. You shouldn't be able to break it, but if it doesn't latch in position then you have a line fault somewhere. Unplug everything first before resetting
If the power is on and the onboard mains battery charger has power, you will have a small plug symbol in the bottom right of the control panel.
