If you have a competent Webasto agent nearby, then yes, they should be able to diagnose it. I also had problems with mine. Tried to find a Webasto work shop here in Oslo, but it was not easy. When I finally found one, the had the car for a couple of hours then charged me for the diagnostic service, 350 euro. They told me that I had to replace the whole heater at the total cost of 2400 euros. I didn’t accept that offer. Went home and decided to do everything my self. Long story short, it ended with me replacing the glow plug and burner, cost me 240 euro. Now worked 100% fine for 7 months. I also have a remote to be able to start it without the engine running (preheat the engine in the winter).
If it is the combustion fan the part is availble, part number 1322649A, google it. You could also buy a used ThermoTop C or similar to strip for parts. Anyway you should also consider to replace the glow plug and burner assembly.
https://standheizung-ersatzteile.co...ebasto/repair-parts/25258/brenner-tt-c-diesel
If you decide to do it your self, here is some description. Bare in mind that it is a big project if it is the first time. But not extremely difficult.
First of all, disconnect the starter battery and the second battery under the seat.
1. Remove three plastic covers underneath to reveal the Webasto. In the same time you have to remove the diesel cooler. The in and out fuel line simply disconnects by pushing in a smal button in the end of the fuel line. The diesel will not start to pour out..
2. Drain the coolant by disconnect one of the hoses in the T connection next to the Webasto. Collect the coolant in a clean container if you want to reuse it. Then disconnect the two coolant hoses that runs up to the engine compartment.
3. Undo/remove the smal exhaust pipe, the fuel line to the heater and three electric connections to the coolant pump, fuel pump and the heater it self.
4. Undo the bracket/basket that holds the Webasto and lower it carefully to the ground with suitable jack.
5. Undo the Webasto from the bracket/basket to be able to work on it in a comfortable place. It is easy to disassemble the Webasto. Carefully remove a cover to undo two electric connectors. Then continue on with screws that hold the combustion fan to the burner chamber. And so on. You need new gasket which you get if you buy the glow plug and burner unit...
6. When done, put everything together again in reverse order.
7. Top up coolant.
