Stu
Guest User
I'm sure most of you are aware that your Cali requires the correct oil which for most is probably of the VW 507 specification (Fully Synthetic 5W30).
VW 507 was originally reserved for vehicles on Longlife Service Regime QG1 however all vehicles with DPF fitted now require VW 507 even if on Time/Distance Fixed Servicing. VW suggest that the use of oils that don't meet this specification can halve the life of the DPF.
So with with that in mind it is important to have some oil to hand at all times especially on long journey's and VW 507 is not the easiest to find or cheapest oil on the streets. Whilst scouting around the van today looking for somewhere to stash the spare oil I happened upon what looks to me to be a nice solution. I wondered if you carry oil where do you keep yours??
